Looking for battery model for dry battery AAA or AA
ccchang
Country: Taiwan
Post by ccchang » July 22nd, 2020, 1:47 am
I am looking for battery model for dry battery AAA or AA (not alkaline battery)
Re: Looking for battery model for dry battery AAA or AA
Post by Andrea C » July 22nd, 2020, 3:21 pm
Is that a zinc carbon battery?
I’m curious for your application.
If we generate one for you using our 2450 SourceMeter, the model is impacted by the current used during the discharge. Can you tell us more of your use case?
ccchang
Country: Taiwan
Post by ccchang » July 24th, 2020, 7:07 am
Our IoT devices need these zinc carbon battery models because of alkaline leakage problems.
We are looking for two battery models that are capable of supplying 250mA from a single AAA/AA cell or 2-cell AAA/AA.
Our IoT applications as attachment.
We are grateful for you to help us.
2-cell battery model(AAA or AA).jpg (596.65 KiB) Viewed 323 times
1-cell battery model(AAA or AA).jpg (619.98 KiB) Viewed 323 times
Post by Andrea C » July 29th, 2020, 6:10 pm
Thank you for this info.
I have the zinc carbon batteries ordered. They are not so common here in the States.
Post by Andrea C » August 11th, 2020, 1:01 pm
I have some batteries in hand.
Just to review, we know that the model for a battery is dependent on the rate at which the charge is extracted.
From a typical battery data sheet:
typical datasheet curve
With a SourceMeter, we can easily do this constant rate of discharge until the voltage is depleted to some lower limit (~0.9V).
We can also do more complex waveforms. Our battery model generation script that runs on the 2450 or other touch screen models supports a list of up to 10 currents each with their own dwell time.
Here are two cycles using:
200mA for 10msec
20mA for 90msec
100uA for 400msec
scope shot of pulsed charge extraction
Using that waveform, we are pulling just a little over 2uA-Hrs each second.
If the AAA battery is nominally 1000mA-Hrs of capacity, this is very long time to generate the model and beyond what I can allocate to.
I'll start with a AAA (~1000 mA-Hrs) and discharge at 100mA or 0.1C.
Post by Andrea C » August 11th, 2020, 4:51 pm
Here is battery model for 2281S battery simulating power supply.
It was generated with 100mA constant discharge with script on 2450 SourceMeter.
The battery is a carbon zinc Panasonic UM-4NP or AAA.
aaa_ZnC_100mA.csv
100mA constant drain
(3.25 KiB) Downloaded 18 times
ccchang
Country: Taiwan
Post by ccchang » August 18th, 2020, 2:02 pm
I am very grateful for the trouble you have taken to examine our demands and comment on it in such detail.
Your suggestions will be very helpful to us.
This makes me all the more appreciative of the time you have so generously given.
Return to “Other Power Supplies”
