248 High Voltage Supply Resolution
diamon153
Post by diamon153 » June 12th, 2015, 11:37 am
I am using Keithley 248 high voltage supply, and it seems that the voltage resolution is 1v when using the front panel.
Would it be possible to get better resolution (0.1v or 0.01v) when I'm programming it through labview/command control?
I would like to able to make fine changes at high voltage (around 3kv).
Thanks.
brian.d.smith
Re: 248 High Voltage Supply Resolution
Post by brian.d.smith » June 12th, 2015, 1:23 pm
Have a look at the document 248_DocSpec.pdf This is the formal specification. The voltage resolution for set and display is 1V with an accuracy of 0.01% of setting and 0.05% of range.
