Looking for a "programmable DC power supply"
peter7139
Post by peter7139 » October 27th, 2015, 12:05 pm
We are looking for a "programmable DC power supply" using in testing automotive LED lamp.
I am not sure whether the name above is the right one to call the equipment but let me describe what we need:
Recently our customer gave us a "Start/Stop battery voltage curve" and asked us to test lamp with this curve but we don't have a test equipment can do it. I attached the voltage curve so that you can check it.
Our need is:
1. DC power supply that can generate voltage curve and input into our products.
2. Estimated max power rating: 300W; 30V; 10A.
3. Good resolution
Looks like 2281S-20-6 Precision DC Supply and Battery Simulator might be a good choice for us but we're open-minded to have more recommendation from you.
Thank you for helping me.
Sincerely,
Kuei Kuo
Start_Stop Waveform.docx
(185.03 KiB) Downloaded 1037 times
Re: Looking for a "programmable DC power supply"
Post by Dale C » October 28th, 2015, 12:17 pm
]The Model 2281S has a list mode to do these types of waveforms. But it is not fast enough.
the response time is around 10 to 20msec.
I would recommend the Model 2651A source meter for this application.
Take a look at the attached application note using the 2651A.
ARB Waveform 2600B.pdf
(743.72 KiB) Downloaded 1051 times
