C# example for PWS4205 or PWS4000
Vinod D A
Post by Vinod D A » March 17th, 2017, 1:21 am
We have a power supply PWS4205 and would like to control remotely to set and clear voltage.
Please let me know if there are any examples availble to control the Programmable powersupply through C#.
Thank you,
Vinod D A
Raghu R
Re: C# example for PWS4205 or PWS4000
Post by Raghu R » April 3rd, 2017, 1:56 am
We support with IVI-COM drivers for the PWS model 4205. You could use to build a custom program in C environment.
Alternatively you could use the LabVIEW Signal Express tool at the link below.
http://www.tek.com/search/apachesolr_se ... 3Asoftware
Regards
Raghu
vinod4205
Post by vinod4205 » May 11th, 2017, 2:06 am
In WINDOWS 10, we are able to control the Power supply PWS4205 through TekVISANET.dll from C# program. However only the 32 bit dll is working. and 64 bit dll has architecture mismatch issue.
This issue seen with few windows systems.
Does Tektronix team has the OpenCHoie TEKVISA package for WINDOWs 10?
//Vinod
