current regulated power supply
Gilles
Post by Gilles » May 30th, 2012, 1:27 pm
I am working in University of Houston on an electroplating process, hence I am looking for a regulated current supply. I will need a device that supply constant current, with the possibility to set it between 1 and 10 mA. The voltage will be followed by a multimeter. Do you have that kind of devices? All regulated power supplies seems to be regulated in voltage and not in current. Can you indicate me if which models fits my requirements?
Re: current regulated power supply
Post by Dale C » May 31st, 2012, 5:31 am
Model 6220 should help.
This is a constant current source that can output from 1pA to 100mA.
If you need higher output current then the Model 2401 Source Meter can help.
Here are the links to the data sheets.
http://www.keithley.com/support/data?asset=15911
http://www.keithley.com/support/data?asset=55849
