DAS-1600 Series Power Amplifier
jlee_kaz
Post by jlee_kaz » September 6th, 2012, 11:25 am
I have a fairly old power amplifier, and I am having a hard time figuring out what the exact model is. It has "DWG1439" on the front, but I can't find another serial numbers on it elsewhere.
The only clues I have are that I have a bunch of floppy disks that is software for the 'DAS-1600 series' and 'ASO WIn 95 32-bit' driver information that dates back to 1995. Furthermore, it is connected to a physical port on the back of the computer that was running Windows 98 (computer is pretty dead now). There is a Borland C++ script that was used on that computer in order to control the power range and cycling.
I'm trying to figure out how/if I can use this power amplifier on another newer computer, along with the C++ script. Are there newer cables that I can use to connect it to the computer? I understand that new computers probably don't have that kind of port. Also, is there any other way to install driver and software for this power amplifier? I don't have any computers with floppy drives.
Re: DAS-1600 Series Power Amplifier
Post by Dale C » September 6th, 2012, 11:35 am
Here is a link to the DAs-1600 series drivers on the KI web site.
Maybe that will help.
Also here is a link to all the information about the DAS-1600 series that Keithley has to offer on this obsolete unit.
http://www.keithley.com/support/keidoc_ ... m_type=All
jlee_kaz
Post by jlee_kaz » September 6th, 2012, 12:59 pm
From the FAQ, it appears that the ISA boards for the DAS-1600 Series cannot be used for any of the newer computers. However, I am asking about connecting the power amplifier (DWG-1439) unit.
Do you know of any other way to connect a Windows 7 Prof computer to the power amplifier in order to make it run the C++ program, or do I need to purchase a new power supply?
Post by Dale C » September 6th, 2012, 1:37 pm
Looks like a new supply would be the way to go.
jlee_kaz
Post by jlee_kaz » September 6th, 2012, 2:07 pm
What model would be similar to the one that I am using? From what I understand, the power supply was used to operate a Langmuir probe that measured plasma density, and the C++ code controlled the voltage sweep setting and the cycling time.
Basically, the probe went from a low potential to a high potential for many cycles. During the sweep, current would be collected from electrons from the plasma, and it would spit out the current collected vs. voltage.
Post by Dale C » September 7th, 2012, 5:37 am
Sorry. Keithley has no power amplifiers on a DAQ card.
If this is what you need, the I would recommend "Data Translation". They may have something for you.
jlee_kaz
Post by jlee_kaz » September 7th, 2012, 9:28 am
Ok, I think I'm starting to understand what is going on. I did some more digging, and I believe that the power amplifier is actually home built by our electronics department. However, that department closed down a while back.
Does Keithley have any USB compatible DAQ that functions similar to the obsolete DAS-1600? Or do most DAQ devices perform in similar manners? Basically, I am wondering if there are any hardware incompatibilities in general.
Post by Dale C » September 10th, 2012, 6:41 am
Take a look at the KUSB-3100 series.
Here is the link.
http://www.keithley.com/support/data?asset=50072
jlee_kaz
Post by jlee_kaz » September 10th, 2012, 5:04 pm
The connector for my power amplifier to the DAS-1600 is a 37 pin D connector. Is this compatible with all of the KUSB-3100 series?
Post by Dale C » September 11th, 2012, 10:58 am
A single USB cable, shipped with each KUSB-
3100, -3102, -3108, and -3160 module, provides
both power and signal connections from your
PC. No external power supply or battery is
required. The KUSB-3116 includes a USB cable
and +5V 2A power supply and power cable.
Signal connections are made directly to each
module using either screw terminals, BNC
connectors, or 37-pin D-type connectors located
on the module itself. The KUSB-3102 and -3108
provide removable screw terminal blocks. Pin
assignments are clearly marked on the module
labels for quick setup.
