Could you please provide further information on performing this operation.
Taken from manual.
"The 2015 can return the levels of individual harmonics (relative to the level of the
fundamental, in dB). The parameters for this command are the starting and ending harmonics.
Specify 2,3 for the second and third harmonics, or 2,2 for the second harmonic. The harmonic
levels returned correspond to the last triggered reading, and the unit has to be set for one-shot
readings (:INIT:CONT OFF). For remote operation, send this command:
:SENSe:DISTortion:HARMonic:MAGNitude? xx,xx ;query individual harmonic levels"
Retrieve magnitude of individual harmonic (Page 2-38 of User Manual)
- Keithley Applications
- Country: United States
- Contact:
Re: Retrieve magnitude of individual harmonic (Page 2-38 of User Manual)
Attached is some more information about the 2015.
Could you elaborate on what you require?
Ok. I'll try and get my hands on a gpib to usb cable and attempt to use this functionality.
