Just got a used 2015 THD
2015, 2015-P, 2016, 2016-P
Bingo600
Country: Denmark
Post by Bingo600 » April 5th, 2013, 8:33 am
Hi Forum
I just got a used 2015 THD DMM.
I was wondering if it basically is a 2000 with a THD addon.
The reason is that there isn't much info or forum entries for the 2015 , and i was wondering if i could also use the info from the 2000 forum.
It's doing burn in test right now , using a Geller 10v reference.
And is actially closer to the 10v (9.99992v) than my Agilent 34401a (9.99978v)
TIA
Bingo
Re: Just got a used 2015 THD
Post by Dale C » April 8th, 2013, 12:32 pm
The Model 2015 is a Model 2000 measurement engine for DCV, ACV, DCI, ACI, 2 and 4 wire ohms, temperature and frequency.
The Model 2015 has he THD function and that separates it from the Model 2000.
So all other functions can be used as a Model 2000.
Bingo600
Country: Denmark
Post by Bingo600 » April 9th, 2013, 12:29 pm
Hello Dale / Keithley
Thank you for the ansver.
I'll have a look in the 2000' forum.
Btw:
I have goofed in my Geller Reference measurements (by connecting 3 meters at the same time to the reference).
http://www.gellerlabs.com/SVR%20M.html
I got an advice from Joe geller, about only conecting one instrument at the time ...
And the Keithley hit the magic number (- further down) .... :D
http://www.eevblog.com/forum/reviews/ke ... #msg213755
The 2015 is spot on , and my 34401A is 7 ppm off.
Not bad for a Volt-nut beginner (hobbyist)
/Bingo
Return to “Series 2015 & 2016 THD/Audio Analyzers”
