SCPI Programming
hugof86
Country: Portugal
SCPI Programming
Post by hugof86 » June 19th, 2015, 3:08 pm
I'm kinda new in scpi programation, nevertheless i make a program in c# (to control my model 6487) and one part is coded below as pseudo-code:
            Write("FORM:ELEM READ,TIME");
            Write("TRIG:COUN 100");
            Write("NPLC .1");
            Write("TRAC:POIN 100");
            Write("TRAC:FEED SENS"));
            Write("TRAC:FEED:CONT NEXT");
            Write("SYST:ZCH OFF"); Delay(5000);
            Write("INIT"); Delay(5000);
            Write("TRAC:DATA?"); Delay(5000);
            Write("CALC3:FORM MEAN"); Delay(5000);
            Write("CALC3:DATA?");
            Read();
So.. I use this code (based on a example of keithley) and when i read the buffer i'm getting the 100 valors and not the average. If i change the numbers of valor needed to average to 20 or even 50 (like the example) i'm getting the average.
Can u give me some tip about the problem? Thanks.
Norbert W
Re: SCPI Programming
Post by Norbert W » June 22nd, 2015, 1:08 am
here a screenshot of a test using the Keithley communicator software;
Note a *RST added at the beginning; after every query (commands ending with a ?) data are read
by the software. Please try the same and post a screenshot if your results look different.
