KPCI-488LPA & Windows XP Embedded OS
IgorTarasov
Post by IgorTarasov » November 25th, 2010, 2:33 pm
Sorry to disturb you I have some question about GPIB KPCI-488LPA Interface card. Do you know any limitation on using this card on Windows XP Embedded OS? I have two tools using the identical software (VC++). The same drivers (Keithley command support). The system with XP professional does not have any errors at all, the system on Windows XP Embedded produces multiple hanging-up. I really need your help.
Thank you in advance
Igor
Re: KPCI-488LPA & Windows XP Embedded OS
Post by Dale C » November 29th, 2010, 6:57 am
What version of the KPCI-488LPA driver are you using?
After looking at the release notes for this driver, I would recommend version 2.0.
It looks like version 1.2 had some bugs fixed that hung up the GPIB.
Here are the release notes for version 2.
Modification of NI-compatible driver in KEITHLEY CD 1.2
**** Miscellaneous bug fixes ****
* When is in slave mode, a gpib read following a GPIB
write sometimes got stuck.
* When TIMO is set in the wait mask, ibwait returns when the timeout
occures but TIMO bit is not set to ibsta (except the timeout is
caused by GPIB I/O).
* ibwrt is failed when EOS on write is enabled and the write string contains
EOS.
* When a GPIB I/O is in progress, the second GPIB I/O keeps waiting until timeout
instead of directly blocking the second operation.
**** Feature enhancement ****
* Setup program supports Windows 2000/XP/Vista system.
IgorTarasov
Post by IgorTarasov » November 29th, 2010, 10:34 am
Hi! Thank you for advice.
But I DID NOT use NI compatible driver. I uses driver from CD originally shipped with card.
I will try to use version 2.0
Stuart M
Keithley
Keithley
Post by Stuart M » December 1st, 2010, 8:34 am
Actually the latest driver version is now 3.06.
http://www.keithley.com/support/data?asset=52970
