KUSB-488A and KUSB-488B Differences
stevenlis
Post by stevenlis » December 7th, 2010, 8:27 am
I have both the A and B versions. The A version has been working fine for years. When I replaced it with the B version, the software works fine for some actions. However, some software processes cause the B version to "lock up" and provide a complex error message.
Are there setting that I can change on the B version to make it identical to the A version?
Tom Sw
Re: KUSB-488A and KUSB-488B Differences
Post by Tom Sw » December 7th, 2010, 5:09 pm
I am not aware of any settings you can change. Did you install the Keithley or National Instruments compatible version and have you downloaded the latest version of the driver? You can download the latest version here:
http://www.keithley.com/support/keidoc_ ... are+Driver
Stuart M
Post by Stuart M » December 8th, 2010, 9:21 am
You must install the KUSB-488B as keithley command compatible if you want CEC like funcationality.
There are bug fixes, so be sure to download latest driver now at version 3.06.
http://www.keithley.com/support/data?asset=52970
djalilosse
Country: Algeria
Post by djalilosse » January 6th, 2013, 5:06 am
hi all, i have a version KUSB-488A, my PC content the ubuntu12.04, so,
my problem is :
Where I can find the driver KUSB-488A which is compatible with Linux?
and how I can it install under ubuntu 12.04lts? (The steps of the installation)
Post by Dale C » January 7th, 2013, 6:29 am
I do not know if the KUSB-488A is compatible with linux.
Here is a link to the latest driver for the KUSB-488A.
http://www.keithley.com/support/data?asset=53029
Return to “Instrument Accessories & GPIB”
