Here is the code:
ROUT:MULT:OPEN (@101:142)
SENS:FUNC 'RES', <clist>
ROUT:SCAN <clist>
SAMP:COUN 5
ROUT:SCAN:TSO IMM
ROUT:SCAN:LSEL INT
READ?
When I was opening the channels with ROUT:OPEN:ALL, everything was fine, but now I get the mentioned error.
The thing is, I cannot use :OPEN:ALL because that would also open the relays, which is not an option because testing machinery will be hooked up to them. But I am opening all channels of the MUX before the measurement, so I don't know why I get the error.
How could I modify the code to make it work?
edit:
I have working TSP code for this functionality, I would just like to implement it for a multimeter that doesn't support TSC.
scan.mode=scan.MODE_OPEN_SELECTIVE
scan.create('<clist>', '<configuration>')
state = scan.execute(buffer)
printbuffer(1, buffer.n, buffer)
buffer.clear()
