Keithley 7168 Nanovolt Scanner
blaffie
Country: South Africa
Post by blaffie » August 4th, 2014, 4:09 am
Good Day
I need to build an experimental setup using the Keithley 7168 Nanovolt Scanner with a Keithley 7001 Switch. I had the problem where the 7001 did not detect the 7168, but I think a previous post will solve that problem.
My question is how does one use the 7168 Nanovolt scanner with LabVIEW. I could not find any drivers for this device. I am new to LabVIEW and I do not know how to add new test equipment to the vi.
I did find the 7001 drivers.
Re: Keithley 7168 Nanovolt Scanner
Post by Dale C » August 6th, 2014, 8:21 am
The Model 7001 does automatically recognize the Model 7168.
Use the CARD button to let the 7001 know which slot the 7168 is in.
The Labview drivers are at this link.
It is not necessary to use the drivers to control the Model 7001 through Labview.
You can always use VISA Or GPIB WRITE and READs.
:ROUTE:CLOSE (@1!1)
this closes channel 1.
Return to “LabView Drivers”
