How to mesure Stair Case Sweep
md_mosleh
Post by md_mosleh » May 8th, 2015, 7:14 am
Hi ,
I am using keithley 2400 for solar cell testing. I need to supply voltage from -1 to 1 Volt and get the current output for 200 points. I think i need to use stair case sweep . By using standard Keithley Driver provided by NI how can i use that ? For linear sweep if i select 200 points it gives errror. It can give the result only for maximum 100 points.
Norbert W
Re: How to mesure Stair Case Sweep
Post by Norbert W » May 8th, 2015, 7:58 am
not knowing the error code you get I want to share a guess of what might happen:
There is often a maximum number of bytes (e.g. 256) for reading data used in drivers which limit the
number of readings which can be transferred. Please give it a look - and let me know
the original error code if this does not improve the situation.
brian.d.smith
Post by brian.d.smith » May 10th, 2015, 3:09 pm
I suggest writing the SCPI script first and then calling that script from your GUI application.
You could also use a pre-written 2400 Labview Sweep Voltage application found here
http://www.keithley.com/support/keidoc_ ... m_type=All
Return to “LabView Drivers”
