2182A & 6221 Labview Drivers
OrStudent
Country: Israel
Post by OrStudent » August 21st, 2016, 1:30 am
2182A NANOVOL TMETER & 6221 DC and AC Current Source. Labview Drivers. can i got the Their latest version ?
And a version of an updated both working together ?
Re: 2182A & 6221 Labview Drivers
Post by Dale C » August 22nd, 2016, 6:46 am
There is no one driver that controls both the 2182A and 6221.
For the 2182A the Model 2182 driver is available at this link.
http://www.tek.com/specialty-instrument ... -6i-driver
For the 6221 the driver is at this link.
http://www.tek.com/specialty-instrument ... ject-style
pvrkaranth
How to sweep Nanoampere current in Keithley 6220 current source with Labview 8.6?
Post by pvrkaranth » August 22nd, 2016, 8:51 am
I am interfacing Keithley 6220 current source by Labveiw 8.6 through GPIB bus and KUSB 488A. I am using example VI which is provided with Keithley drivers for current sweep. I don’t have any problem in sweeping the current in micro or milliamps. But when try to sweep in nanoampere (even the step level in nanoampere), it shows error message “-222” which stands for “Parameter data out of range”.
Can anybody please help me to resolve this error to sweep in nanoampere (stop level as well as step level in nA). I am herewith attaching the the VI which I am using. Front Panel during run (which shows my controls) and the error message are also been attached.
Thanks in advance
KE622x -- Execute Current Sweep Example.vi
(44.53 KiB) Downloaded 1125 times
Front panel.doc
(136.5 KiB) Downloaded 1080 times
Post by Dale C » August 22nd, 2016, 11:22 am
I have run the Labview driver current sweep example from Labview driver ver 8.
It seems to run fine.
I tried it with
Start at 1e-9A
Stop at 1e-8A
Step at 1e-9A steps.
It worked with no trouble.
The driver is attached.
Keithley_622x_LV_8.zip
(4.67 MiB) Downloaded 1232 times
Return to “LabView Drivers”
