When will 2450 smu labview driver available?
Theerapong
Country: Thailand
Post by Theerapong » September 21st, 2018, 10:27 pm
I am looking for 2450 smu labview driver, but only old version of 24xx smu on the list.
So, when will it available for user.
Stuart M
Keithley
Keithley
Re: When will 2450 smu labview driver available?
Post by Stuart M » September 24th, 2018, 6:56 am
The driver is posted here and supports three different models:
Keithley 2450, 2460, 2461 Native LabVIEW 2015 Instrument Driver version 1.3.0
https://www.tek.com/source-measure-unit ... oftware-10
Theerapong
Country: Thailand
Post by Theerapong » October 5th, 2018, 2:46 am
Thank you for your help.
I try to install it by following this guide.
https://www.youtube.com/watch?v=DKCpkPIT9Xg
But, I cannot install this driver with Labview NXG.
How can I do that?
Post by Andrea C » October 5th, 2018, 6:01 am
I do not know about the automatic instrument driver detection scheme of the LabVIEW NXG. I suggest you contact National Instruments for support on that.
If you want to do some diagnostics on your own,check two things.
One: in NI-MAX, is the 2450 detected? Not sure if you are using GPIB, or USB or Ethernet.
Below shows successful detection of a 2450 connected over GPIB.
Two: for the LabVIEW driver from our web site, the install instructions would have you unzip it to this location. Check that. That may be sufficient to have the NXG begin "to see" the driver.
NOTE: your LV version name will be different from my old 2014 one.
Return to “LabView Drivers”
