Where to download sub VI's for "S46 Driver Common.vi".
pconway
Post by pconway » February 3rd, 2014, 1:22 pm
Hi-
I just downloaded the driver for S46T.
I get errors when loading sub VI's.
The error is for a missing sub-VI's under"S46 Driver Common.vi".
Anyone know where to access those sub-VI's?
for example...
KeSys46 Close Channels.vi
KeSys46 Open Channels.vi
KeSys46 Query Closed Channels.vi
KeSys46 Query Closure COunt.vi
...etc.
Thx.
Stuart M
Keithley
Keithley
Re: Where to download sub VI's for "S46 Driver Common.vi".
Post by Stuart M » February 4th, 2014, 6:25 am
The attached llb should contain the VIs you are looking for.
Just unzip and place in KeSys46.LLB file in the C:\Program Files\National Instruments\LabVIEW xxxx\instr.lib\KeSys46 directory.
Best regards.
KeSys46.zip
KeSys46.LLB (updated)
(469.93 KiB) Downloaded 1504 times
pconway
Post by pconway » February 4th, 2014, 4:17 pm
Stuart-
Thanks.
That worked well and LabView can now find them.
Next question- I'm using LabView2012, so these are too old to be loaded with my version.
Is it possible for someone at Keithley to update these drivers from LV ver 5.11 to ver 2012?
Thx.
Stuart M
Keithley
Keithley
Post by Stuart M » February 5th, 2014, 6:22 am
I'm a bit confused.
If you use the KeSys46.LLB that I have provided in place of the old llb file, it should be new enough to open in LV 2012.
Return to “LabView Drivers”
