Loadandrunscript in the nonvolatile memory
sebbastiannn
Post by sebbastiannn » November 23rd, 2021, 7:22 am
Hello :D
I would like to save my Lua script in nonvolatile memory on the Keithley 2614B.
I am using a Keithley 2614B (connected via USB) and wanted to do this via the TSB Software. The system was switched from a 2601B to 2614B.
For the measurements on the old keithley everything was controlled via Labview and it needs the "hysteresis" function (see Lua script), but I just can't get it into memory.... :?
When I put the script into the TSB I get the Error:
2003, EndScript without LoadScript
-285, TSP syntax error at line 1: `=' expected near `Hysteresis'.
I tried to google this but I only found out that in TSB itself you don't have to use loadandrunsscript. However, in the Keithley 2600B manual I found this:
1. Load a script (see Create and load a script (on page 6-3)).
2. Send the command scriptVar.save("/usb1/filename.tsp"), where scriptVar is the
variable referencing the script and filename.tsp is the name of the file
Means that I have to use loadscript, if not I get the error that it doesn't know the script name.
The script itself should be correct, because the same was used before on the old Keithley 2601B to measure :| .
In the code itself is still missing the Hysterese.save() but at the moment it doesn't even work like that haha
This is definitely something simple i'm missing, I hope you have some advice :D
loadandrunscript Hysterese
function HystereseV(startv, stopv, stepv, points)
htable = {}
count = 0
if startv < stopv then
while count < points do
htable[count + 1] = startv + stepv * count
count = count + 1
end
while count < points * 2 do
up = count - points
htable[count + 1] = stopv - stepv * up
count = count + 1
end
else
htable[count + 1] = startv - stepv * count
count = count + 1
end
up = count - points
htable[count + 1] = stopv + stepv * up
count = count + 1
end
end
smua.trigger.source.listv(htable)
end
endscript
sebbastiannn
Re: Loadandrunscript in the nonvolatile memory
Post by sebbastiannn » November 24th, 2021, 7:31 am
Hey :)
I found out that the command loadandrunscript is used when you want to feed the script with usb stick.
I will try this tomorrow i hope it works.
But I would still be interested in what changes I would have to make to the script, that I could save it via the TSB software directly to the Keithley without using a USB stick (just personal intrested) :D
Post by Andrea C » December 3rd, 2021, 7:16 am
To load your script from Test Script Builder tool, use the Run Configurations for the TSP Project in the navigator.
Here I do very simple beep script:
TSB for loading script to instrument memory
Here you can see the result on the instrument NVMemory. Use Load button; navigate to scripts. Scroll to your script and press enter.
This loads to the runtime memory and makes available for execution.
Press Run button to execute it.
Instrument front panel
Last: from the instrument console, you can remove scripts:
TSB for removing scripts from instrument memory
