debug error form Help contents Example
WenHsien
Country: Taiwan
Post by WenHsien » August 30th, 2012, 8:52 pm
I want to try Help contents Example: Debugging with a conditional breakpoint, when select Run As > TSP File, the script runs fine, but select Debug As > 1 TSP File. The script show error message.
Test Script Builder Version is KTS-850E01
Please help me, thank you.
error message
debug error.JPG (32.14 KiB) Viewed 16468 times
Re: debug error form Help contents Example
Post by Andrea C » August 31st, 2012, 11:18 am
In the Instrument Console Window, send a *IDN? command to your instrument, and let us know the response.
Also, what version of Windows is Test Script Builder installed on?
WenHsien
Country: Taiwan
Post by WenHsien » September 2nd, 2012, 6:38 pm
Thanks your help.
Windows version is xp SP3.
Post by Andrea C » September 3rd, 2012, 6:48 am
Thanks for the info.
In order to use the debug feature in version E01 of Test Script Builder, the 2612A needs to be at firmware version 2.2.2 (or higher).
Your instrument is as 2.1.6.
You can download the firmware from here:
http://www.keithley.com/support/keidoc_ ... e=Firmware
Andrea
WenHsien
Country: Taiwan
Post by WenHsien » September 3rd, 2012, 8:30 pm
Hi,Andrea
The debug mode can work now.
Thanks for your help.
