TSPeXpress Java Security Warning - Application not executed
Allen O
Post by Allen O » September 6th, 2012, 9:36 am
Problem: You cannot get Java to launch to run TSPeXpress due to a Security Warning that states the certificate cannot be validated, but yet it works in the office with a wireless connection and the crossover or network cable.
Solution: At the is point I have assumed the network setups/connections are all correct and you have installed, un-installed, then re-installed the correct version of the Java Runtime Environment (JRE) and still have the problem. The problem is that there are two versions of the JRE, an on-line version for when one is connected to a network and an off-line version when one is in standalone mode or still connected to a network. One needs to make sure that the off-line version of JRE is installed. Typically the file size is much larger than they on-line version.
-Allen
Java Failed Certificate Validation
