how to use TSP express software
jiamawork
Post by jiamawork » July 14th, 2011, 6:00 pm
how to use TSP express software and 2601A source meter to perform battery charge and discharge tests?
Gabriele V
Country: Italy
Re: how to use TSP express software
Post by Gabriele V » July 15th, 2011, 7:08 am
Hello jiamawork,
TSP express is especially designed for a device characterization and curve tracing.
For your application I would suggest to use the scripting that give you better performances and more control on the charge and discharge process.
May be during the charge you want to check the "Negative Delta Voltage" point for your battery and this is possible using script because the unit can take decision during the execution. If you need you can also define a loop for trickle charge and so on.
A the same time, if you want to discharge the battery being sure that the voltage does not drop below certain level this is the right approach.
I hope this can help
Regards
Gabriele
Gabriele Vittori
Application Engineer
Keithley Instruments (Italy)
