Load Script Parameters
Use this forum for questions about Keithley Test Script Builder software.
Eigenvector
Country: Slovak Republic
Post by Eigenvector » July 26th, 2013, 3:48 am
Hello;
I'am trying to call a TSL script, stored in the master node 3706A, with unique parameters.
1.) Is it possible to set these parameters on the front panel before running the script manually?
2.) Does TSL support file-management functionality within the USB? i.e. is it possible to load arguments from a .txt file stored on the USB?
3.) Or at last, is there a part of Lua code that handles the communication through TCP/IP between the Switch and a Linux system. As I am able to load arguments in Lua and compile the code in C but I can't send commands to the instrument itself.
thanks in advance
Mat
Return to “Test Script Builder”
