Test Script Eror
MrJaeLane
Test Script Eror
Post by MrJaeLane » August 7th, 2013, 11:51 am
Does anyone know why Im getting this error when installing the Script Editor?
(An ERROR occured while installing installation system components for Test Script Builder KTS-850E02 setup can not continue until all the system compnents have been sucessfully installed."
(Im using Windows7, and Im trying to install script builder version KTS-850E102)
thanks
Jerome
MrJaeLane
Re: Test Script Eror
Post by MrJaeLane » August 7th, 2013, 12:33 pm
More details for the error message:
Setup has detected that the file 'C:\Users\xxxx\AppData\Local\Temp\VSD9A5C.tmp\icp410\icp410\Products\IVI_Compliance_Package\ICPCore.msi' has either changed since it was initially published or may be corrupt.
See the setup log file located at 'C:\Users\jhoward\AppData\Local\Temp\VSD9A5C.tmp\install.log' for more information.
