Pulse mode from 2636A
HelenNIU
Country: France
Post by HelenNIU » November 19th, 2013, 7:58 am
We have a SMU2636A which has 2 SMU in it (SMU-A and SMU-B) and now I need now use the both to perform a pulse measurement on a JFET. The SMU-A polarizing the drain has to provide a long pulse during which the SMU-B polarizing the gate provides a short pulse. I am a beginner for this software. Can you give me some ideas to make it?
Thanks a lot!
Re: Pulse mode from 2636A
Post by Dale C » November 19th, 2013, 8:20 am
What communication bus are you using?
If it is Ethernet then you might consider using TSP Express. This is a gui type program embedded in the 2636A. There is nothing to down load or install.
It can only be accessed through ethernet.
Here is a link to a short video that shows how to use this software.
http://www.keithley.com/centralized_dis ... etid=57371
If you want you can use TSB (Test Script Builder) and write your own script.
There are many example scripts on the KI site at the following link.
http://www.keithley.com/support/keidoc_ ... le+Program
