Steps to use the KUSB-488B for 6517B
yongning
Post by yongning » September 2nd, 2014, 10:39 am
i've installed the KI-488_Driver_Version_3.12 for my new KUSB-488B:
then i plugged it into the connector of 6517B and my laptop, after which i followed the prompts to finish the installation of the hardware.
kann i now use the following program? are there some problems? the new 6517B is an expensive instrument, so i muss ask something before using.
What's the steps to set the uniform GPIB-Address on both the software and the 6517B?
thanks
Re: Steps to use the KUSB-488B for 6517B
Post by Dale C » September 2nd, 2014, 10:53 am
1. Select the communication interface to GPIB.
2. Select the appropriate VISA resource name. Model 6517B default GPIB address is 27.
Then select the appropriate parameters and click on RUN.
yongning
Post by yongning » September 3rd, 2014, 2:03 am
What is the settings for R-Measurement? We can only measure the V.
Would you show me a snapshot?
Should I set something on the 6517 front panel?
Post by Dale C » September 3rd, 2014, 10:35 am
Use the Sense function pull down menu on the left hand side of the screen.
It has voltage, current, resistance and charge as selections for measurement.
But do not forget, with the Model 6517B the unit needs to source voltage and measure current to make a resistance measurement.
So that means you need to choose a voltage under the DC Bias field.
YangUVa
Post by YangUVa » October 17th, 2014, 12:41 pm
Hi, how can I get this kind of application software for 6517A/B?
Did you do the program by yourself?
Thanks.
Post by Dale C » October 20th, 2014, 6:30 am
I uploaded this program to the Keithley FTP site.
ftp://ftp.keithley.com
user name = kicust
password = w3lc0m3
This spells welcome but the vowels are integers.
Look for the 6517B Software folder.
It will be in that folder.
YangUVa
Post by YangUVa » November 4th, 2014, 2:41 pm
Great!
Many thanks! :D
tburgo
Country: Brazil
Post by tburgo » February 11th, 2015, 10:11 am
Hi Dale,
Is there something like this software but for Keithley 6514?
Thiago.
Post by Dale C » February 11th, 2015, 10:30 am
The closest software to control the 6514 would be Excelinx-2A.
Or maybe the Labview driver has some example in it.
But that is about it.
hribal
Country: Czech Republic
Post by hribal » November 5th, 2015, 4:29 am
is there any way to download control software for 6517B? Links above to FTP doesn't work. :(
Thank you.
Post by Dale C » November 5th, 2015, 7:56 am
FTP has been dismantled.
Contact Keithley for this file.
Return to “LabView Drivers”
