Probe selection
Siva kumar
Country: India
Probe selection
Post by Siva kumar » June 8th, 2017, 10:30 pm
Hi ,
I am having an Tektronix osciloscope TBS1102 , i tried to measure the signals in the SMPS using that and probe TPP0101(300V) ,At once i touched the ground terminal (which is Pin 2 of the IC in attached schematics ) MCB got tripped .Please guide me whether i am using the right probe or do i need to change the probe.
SMPS.docx
(206.3 KiB) Downloaded 1400 times
Re: Probe selection
Post by David N » June 12th, 2017, 3:13 pm
If you are using the standard probes that came with the TBS1102, when you attach the probe ground lead to the IC pin 2, you are actually connecting pin 2 to earth ground. If your design is not tying pin 2 to earth ground, then you should consider using a HV differential probe. Such as the P5200A or P5205A.
Return to “High Voltage”
