[2281S] - How can I specify a battery model name in internal memory using SCPI?
2280S-32-6, 2280S-60-3
metocean
Country: Canada
Post by metocean » March 14th, 2019, 1:11 pm
I am sending the VOC and ESR entries through the appropriate BATT:MOD<number> commands, but I cannot seem to find the appropriate command to edit the model name in internal memory before saving it in the device. As a result saving the model fails with error number 710 "Illegal model data setting".
metocean
Country: Canada
Re: [2281S] - How can I specify a battery model name in internal memory using SCPI?
Post by metocean » March 18th, 2019, 10:15 am
As an update to this post, I still cannot figure out how to rename a battery model, but the 710 error was due to data not following the ascending/descending values as expected for the VOC and ESR values respectively. I was using data posted in another thread for the Panasonic CR123A battery,
Return to “Series 2280 Precision Measurement DC Power Supplies”
