How to clear output queue
mlaursen
Country: Denmark
Post by mlaursen » November 4th, 2019, 3:47 am
I am running TSP scripts on 4 2602B instruments with TSP link. I call the scripts from a VBA macro. In the scripts I make measurements with overlappediv command
smu3.measure.overlappediv(smu3.nvbuffer1,smu3.nvbuffer2)
smu2.measure.overlappediv(smu2.nvbuffer1,smu2.nvbuffer2)
smu4.measure.overlappediv(smu4.nvbuffer1,smu4.nvbuffer2)
I then print the measurements with
printbuffer(1, MaxIterations, smu3.nvbuffer2) --V3
printbuffer(1, MaxIterations, smu3.nvbuffer1) --I3
printbuffer(1, MaxIterations, smu2.nvbuffer2) --V2
printbuffer(1, MaxIterations, smu2.nvbuffer1) --I2
printbuffer(1, MaxIterations, smu4.nvbuffer2) --V4
printbuffer(1, MaxIterations, smu4.nvbuffer1) --I4
To get the measurements into VBA I run a ReadNumber command.
For i = 0 To 4
instrout(i) = instrAny.ReadNumber()
Next i
However, when doing this, the data queue is not cleared. So when I run a second measurement, the first measurement is still in the beginning of the instrout array.
In the TSP scripts there are both smuX.reset and smuX.nvbufferY.clear() in the very beginning of the script.
Re: How to clear output queue
Post by Andrea C » November 7th, 2019, 3:56 am
sounds like ReadNumber() is a function you have written? How does it relate to the data in the smuX.nvbufferX?
After you clear the buffer, see if it indeed has cleared. Interrogate the value of smuX.nvbufferX.n
numberOfReadings = smua.nvbuffer1.n
print(numberOfReadings)
A typical buffer reset function is below. Call it for each of your SMU, e.g., reset_buffers(node[1].smua)
function reset_buffers(smu)
    	-- Prepare the Reading Buffers
	smu.nvbuffer1.clear()
	smu.nvbuffer1.appendmode		= 1
	smu.nvbuffer1.collecttimestamps	= 1
	smu.nvbuffer2.clear()
	smu.nvbuffer2.appendmode		= 1
	smu.nvbuffer2.collecttimestamps	= 1
end  -- function
mlaursen
Country: Denmark
Post by mlaursen » November 7th, 2019, 5:32 am
Hi Andrea,
It is a command from a visa communication library
Set instrAny = New VisaComLib.FormattedIO488
instrAny.Readnumber()
The first thing I do in the functions is to clear the buffer.
smu1.reset()
smu1.nvbuffer1.clear()
smu1.nvbuffer2.clear()
However, I found a solution with the instrAny.IO.clear in the VBA macro. That appears to fix the problem.
Return to “Resistivity Measurements”
