Can 2306 Be used As Two Battery Channels?
Tree2000
Country: China
Post by Tree2000 » October 28th, 2011, 9:45 am
I Want to Use 2306 to Test UA Standby Current.But I Found That 2306 Only have One Battery Channel ,While The Other One Is Charger Channel.
And I Found In The Manual ,Source1 Is battery Channel While Source 2 Is Charger Channel.
I Don't Know If I can Use Channel 2 to Test UUT's Standby Current : 5UA.I found That Read From This Channel,The Value IS Minus!
How To Setup it as Bttery? The Current Dirction Of Charger Is From Simulator To UUT. It is the Same As The Battery,I Think.
Maybe I need Buy Two 2302 To Use two Batterys?
Catherine
Country: China
Re: Can 2306 Be used As Two Battery Channels?
Post by Catherine » November 28th, 2011, 12:41 am
Both of the Battery Channel and the Charger Channel can sink current, the main differents are as follows:
1. DC voltage output accuracy;
2. DC voltage output programming resolution;
3. DC voltage output transient response time;
4. Battery channel has a variable output impedance function while the charger channel hasn't;
5. Pulse current measurement trigger level.
The connection between the DUT and the instrument is as follows, you can find it on page 60 of the 2306 user manual:
sink connection.png (21.09 KiB) Viewed 13372 times
Besides, as you mensioned, 2302 has only one channel, if you want to simulate two batteries, you need to buy 2*2302
Best Regards,
Catherine
Return to “Series 2300”
