two pole switching
two pole switching
Can anyone tell me how the 2 pole switching is done? i have a 7001 multiplexer, with a 7011-C card, and I need to know how to operate the switching from both the front panel and the remote commands. i.e. same bank, same input, but between the Hi/Lo poles, as indicated in the 7011-c manual. Thanks in advance!
- Keithley Applications
- Country: United States
- Contact:
Re: two pole switching
To close channel 1 of bank A on the 7011 card in the top slot.
1. Press SCAN LIST until the SELECT CHANNELS is displayed.
2. Enter in 1!1 from the keypad. Note all you have to do is press 1 twice.
3. Press CLOSE. This will close channel 1 of bank A on the 7011 card in the top slot.
To close channel 1 on bank A on the 7011 card in the top slot with remote control, send the following command.
:ROUTE:CLOSE (@1!1)
:ROUTE:CLOSE (@1!1)
