Windows Software for Keithley KUSB/KPCI products
Locked
DataTranslation
Post by DataTranslation » April 24th, 2015, 11:49 am
The Data Acquisition Omni Software installs drivers and software for Data Translation's USB and PCI data acqusition products. Also compatible are Keithley's KUSB and KPCI equivalent DT parts. The software includes the following, and is available for download here: http://www.datatranslation.com/cd/omni/.
Device Drivers – Both 32-bit and 64-bit drivers are available. These drivers support Data Translation PCI and USB boards under Windows 8 (32-bit and 64-bit), Windows 7 (32-bit and 64-bit), Windows Vista (32-bit and 64-bit), and Windows XP (32-bit only). The installation program automatically installs the appropriate driver for your operating system.
QuickDAQ – QuickDAQ allows you to acquire and display from all Data Translation USB and Ethernet data acquisition devices that support analog input streaming. Combine QuickDAQ with Data Translation hardware to acquire data, record data to disk, display the results in both a plot and digital display, and read a recorded data file. Data can be exported to other applications like Microsoft Excel® and The Mathworks MATLAB® for more advanced analysis.Two additional options can be purchased to add FFT analysis capabilities to the base package.
DT-Open Layers for .NET Class Library – Native .NET set of object-oriented classes for programming Data Translation's data acquisition devices. Any language that conforms to the Common Language Specification (CLS) can be used, including: Visual Basic.NET, Visual C#, Visual C++ .NET with managed extensions, and Visual J#.NET.
DT-Open Layers for Win32 (DataAcq SDK) – DT-Open Layers for Win32 consists of the DataAcq SDK and DTx-EZ. The DataAcq SDK consists of the necessary header files, libraries, example programs, and documentation to develop your own DT-Open Layers data acquisition and control applications. The native 32-bit libraries are supported in Windows 7 (32-bit and 64-bit), Windows Vista (32-bit and 64-bit), and Windows XP (32-bit only). It is intended for use with non .NET languages, such as ANSI C, Visual C++ 6.0, and Visual Basic 6.0.
LV-Link: LV-Link 3 for use with LabVIEW 8.5.1 or greater for 32-bit support, or LabVIEW 2009 or higher for 64-bit or 32-bit support.
DAQ Adaptor for MATLAB: DT-Open Layers interface to MATLAB Data Acquisition Toolbox. Data Translation data acquisition devices must use the 32-bit version of Data Acquisition Toolbox and MATLAB. The 32-bit versions of Data Acquisition Toolbox and MATLAB can be installed on a 64-bit Windows OS.
Locked
