selecting channel
Venkat
selecting channel
Post by Venkat » July 22nd, 2015, 8:08 am
I have bought 2700 DMM and found that the slots (rare panel) for channel input were empty. I would like to use it for measuring the out put of a pressure transducer, resistance of a heater simultaneously. Please tell me what I am supposed to do?
Joseph V
Re: selecting channel
Post by Joseph V » July 22nd, 2015, 9:25 am
Hello
If you want to use the rear panel of the 2700 to connect to multiple DUTs you would need to purchase a plug-in module such at the 7700 which would allow you to measure 20 different devices.
For the transducer you would be able to reach the voltage of it and you could apply a math function to get the resulting pressure and you would be able to read the resistance of the heater, however you will not be able to do both of these measurements simultaneously you would only be able to do the measurements sequentially.
Venkat
Post by Venkat » July 29th, 2015, 10:59 am
Hello Joseph,
Thanks for the reply.
Do I have to purchase any connecting leads along with the 7700 channel module?
What is the basic difference between 7700 and 7703 modules for my application?
Post by Andrea C » July 30th, 2015, 1:58 pm
The 20 channel model 7700 has screw terminals for connections to the wires of your devices.
The 32 channel 7703 does not have screw terminals. You'd have to connect to the 50-pin D-sub connectors.
A technical data book that highlights each of the available card types for the 2700 Series can be downloaded from here:
http://www.keithley.com/support/data?asset=9951
