Acquiring data with KUSB-3108
Jamal_IE
Country: Ireland
Post by Jamal_IE » August 1st, 2015, 1:31 am
I am acquiring Analog input data with KUSB-3108 using LV-Link VIs with Labview on Windows 8.1 platform. I'm using channels 0 and 1 in differential configuration with gain settings of 1 for both channels.I'm acquiring data with sampling frequency of 50,000 Hz and with 20,000 samples per channel with sample mode of continuous samples. When I run application in Labview, it gives an error "Error 202" with description " Invalid buffer handling from library" and application halts. Could you please suggest a solution to fix this issue.
Regards
Jamal
Re: Acquiring data with KUSB-3108
Post by Dale C » August 3rd, 2015, 11:21 am
I would suggest to contact
Data Translation
Tell them you have a DT9806.
This is the same module.
They will be able to help you.
