WVR 7100 preset loading via java interface not working
mdamberger
Post by mdamberger » January 23rd, 2011, 9:11 pm
I've recently updated one of our WVR 7100 with the V6.0.2 firmware update. In restoring presets using the java interface applet. I've tried to load in the presets I saved. But the file selection browse option is grayed out. So I can't browse to the preset files I have saved.
We have five of these 7100's and I'd like to be able to save each preset for each station we monitor, and re-load them after installing the latest firmware.
The workstation I'm running this java applet on is using Java 2 Runtime Environment SE 1.4.2. Could this be a java version incompatibility issue?
Thanks very much.
Marcus Damberger
Engineering
KRQE/KASA
Albuquerque, NM
stampy
Re: WVR 7100 preset loading via java interface not working
Post by stampy » November 2nd, 2011, 10:52 am
Marcus,
In order to save or load presets on the WVR7100, you have to use the web applet tool that is downloaded at http://www2.tek.com/cmswpt/swdetails.lo ... 4971&lc=EN. The ability to save / load presets is the only difference between this applet and the one found on the Remote Interface page.
Regards,
Dan
Tektronix Applications Engineer
Video Product
