I'm playing with the debug serial port of my tds 420 scope.
i've found these things:
- Only 3 wires are actually needed ; gnd, rx, tx. Voltage levels are rs232 standard. With only 3 wires connected, hardware flow control won't work, but shouldn't be a problem.
- you can actually give commands to the scope os, and call functions.
- Help command gives the following output:
-> help
help Print this list
dbgHelp Print debugger help info
nfsHelp Print nfs help info
netHelp Print network help info
spyHelp Print task histogrammer help info
timexHelp Print execution timer help info
h [n] Print (or set) shell history
i [task] Summary of tasks' TCBs
ti task Complete info on TCB for task
sp adr,args... Spawn a task, pri=100, opt=0, stk=7000
taskSpawn name,pri,opt,stk,adr,args... Spawn a task
td task Delete a task
ts task Suspend a task
tr task Resume a task
d [adr[,nwords]] Display memory
m adr Modify memory
mRegs [task] Modify a task's registers interactively
d0-d7,a0-a7,sr,pc [task] Display a register of a task
version Print VxWorks version info, and boot line
iam "user"[,"passwd"] Set user name and passwd
whoami Print user name
devs List devices
cd "path" Set current working path
pwd Print working path
ls ["path"] List contents of directory
rename "old","new" Change name of file
copy ["in"][,"out"] Copy in file to out file (0 = std in/out)
ld [syms[,noAbort]] Load std in into memory
(syms = add symbols to table:
-1 = none, 0 = globals, 1 = all)
lkup ["substr"] List symbols in system symbol table
lkAddr adr List symbol table entries near address
checkStack [task] List task stack sizes and usage
printErrno value Print the name of a status value
periodi secs,adr,args... Spawn task to call function periodically
repeat n,adr,args... Spawn task to call function n times (0=forever)
diskinit "device" Format and initialize RT-11 device
squeeze "device" Squeeze free space on RT-11 device
NOTE: arguments specifying 'task' can be either task id or "name"
- you can use libManagerWordAt to read the actual nvran value.
Seems actually possible to enable options directly from the debug port, without any expensive gpib card.
With the following commands, taken from other threads here in tek.com/forum, should be possible to enable options
libManagerWordAtPut(0x50006, 1) <- Enable option 1M
libManagerWordAtPut(0x50007, 1) <- Enable option 05
libManagerWordAtPut(0x50008, 1) <- Enable option 13
libManagerWordAtPut(0x50009, 1) <- Enable option 2F
libManagerWordAtPut(0x5000a, 1) <- Enable option 1F
libManagerWordAtPut(0x5000c, 1) <- Enable option 2C
libManagerWordAtPut(0x5000d, 1) <- Enable option 3C
libManagerWordAtPut(0x5000e, 1) <- Enable option 4C
libManagerWordAtPut(0x5000f, 1) <- Enable option 2M
libManagerWordAt 0x50006
libManagerWordAt 0x50007
libManagerWordAt 0x50008
libManagerWordAt 0x50009
libManagerWordAt 0x5000a
libManagerWordAt 0x5000c
libManagerWordAt 0x5000e
libManagerWordAt 0x5000f
My oscilloscope has a very old fw version (1.3) that doesn't even have rolling mode; i suspect that this particular fw version doesn't have these options implemented.
does anyone have a firmware update ?
Feel free to test these command, please use with care!
