Python 3: Save Hardcopy to PC, PyVISA - TDS, TPS, TBS 1K-2K Series
Dave W
Post by Dave W » September 17th, 2015, 4:41 pm
This example demonstrates how to use PyVISA to save hard copy screen images to the PC from TBS1000B, TBS1000, TDS200, TDS1000/2000, TDS1000B/2000B, TDS1000C-EDU/TDS2000C, TDS2024C, TPS2000/TPS2000B Series scopes.
My objective with this example was to create a single code example that works for all three of the interfaces on these instruments (GPIB, USB, and RS-232). RS-232 makes the code slightly more complex but, overall it's not too bad.
Enjoy!
# Name:  Save Hardcopy to PC using PyVisa for TDS, TPS, TBS 1K-2K Series Scopes
# Purpose:  This example demonstrates how to save a hard copy screen image from
#   the scope to the PC.
# Created:  2015-09-17
# Development Environment: Python 3.4, PyVisa 1.8, NI-VISA 2015, Windows 8.1
# Compatible Instruments: TBS1000B, TBS1000, TDS200, TDS1000/2000,
#   TDS1000B/2000B, TDS1000C-EDU/TDS2000C, TDS2024C, TPS2000/TPS2000B Series
# Compatible Interfaces:  GPIB, USB, RS-232
# Tektronix provides the following example "AS IS" with no support or warranty.
import time # std library
import warnings # std visa libraries
import visa # https://pyvisa.readthedocs.org/en/stable/
vc = visa.constants # Alias for easier reading
# Modify the following lines to configure this script for your instrument
visaResourceAddr = 'TDS2024C'
fileSaveLocation = r'C:\Temp\HardCopy.bmp'
bufferSize = 1024
# Serial Port Settings
baudRate = 9600
flowCtrl = vc.VI_ASRL_FLOW_RTS_CTS
#flowCtrl = vc.VI_ASRL_FLOW_NONE
# Open session to instrument
rm = visa.ResourceManager()
lib = rm.visalib
scope = rm.open_resource(visaResourceAddr)
scope.timeout = 5000
# Some settings depend on which interface is being used
interface = lib.get_attribute(scope.session, vc.VI_ATTR_INTF_TYPE)[0]
port = ''
if interface == vc.VI_INTF_ASRL:
    lib.set_attribute(scope.session, vc.VI_ATTR_ASRL_FLOW_CNTRL, flowCtrl)
    lib.set_attribute(scope.session, vc.VI_ATTR_ASRL_BAUD, baudRate)
    port = 'RS232'
    startDelaySec = 5
elif interface == vc.VI_INTF_USB:
    port = 'USB'
    startDelaySec = 3
elif interface == vc.VI_INTF_GPIB:
    port = 'GPIB'
    startDelaySec = 5
print(scope.query("*IDN?"))
scope.write("HARDCOPY:FORMAT BMP")
scope.write("HARDCOPY:LAYOUT PORTRait")
scope.write("HARDCOPY:PORT " + port)
scope.write("HARDCOPY STARt")
print("Starting Transfer in: ", end = "")
for x in range(0, startDelaySec):
    print(str.format("{0}...", startDelaySec - x), end = "")
    time.sleep(1)
print("Now!")
# If using RS-232 then need to disable end on termination character while reading the image data
if lib.get_attribute(scope.session, vc.VI_ATTR_INTF_TYPE)[0] == vc.VI_INTF_ASRL:
    lib.set_attribute(scope.session, vc.VI_ATTR_ASRL_END_IN, 0)
# Read the BMP header bytes and extract the file size
warnings.filterwarnings("ignore", category=Warning) #The read will produce a VI_SUCCESS_MAX_CNT warning so suppress
imgBytes = lib.read(scope.session, 14)[0]
lengthBytes = imgBytes[2:6]
fileSize = int.from_bytes(lengthBytes, byteorder='little', signed=False)
bytesLeft = fileSize - 14
# Read the rest of the image
while bytesLeft > 0:
    imgBytes = imgBytes + lib.read(scope.session, bufferSize)[0]
    bytesLeft = bytesLeft - bufferSize
    if bytesLeft < bufferSize:
        imgBytes = imgBytes + lib.read(scope.session, bytesLeft)[0]
        bytesLeft = 0
# Re-enable end on termination character for RS-232
    lib.set_attribute(scope.session, vc.VI_ATTR_ASRL_END_IN, 1)
# Save the bytes to a file
imgFile = open(fileSaveLocation, "wb")
imgFile.write(imgBytes)
imgFile.close()
print("Transfer Complere!")
print("Image saved to " + fileSaveLocation)
scope.close()
rm.close()
