Setting the ramp symmetry in program
mijq
Post by mijq » September 24th, 2015, 7:01 am
I am making a program module for controlling an AFG1022 with some success
The problem is how to set the duty cycle of the square wave (SOURCE1) and the symmetry of the ramp wave (SOURCE2) .
The is my program block:
With my_instrument
.Descriptor = "USB0::0x0699::0x0353::1516582::INSTR::INSTR"
.WriteString("SOURCE1:FREQUENCY:SWEEP 30 kHZ")
.WriteString("SOURCE1:FUNCTION:SHAPE SQUARE")
.WriteString("SOURCE1:VOLTAGE:LEVEL:IMMEDIATE:AMPLITUDE 3.6V")
.WriteString("SOURCE1:VOLTAGE:LEVEL:IMMEDIATE:OFFSET 1.4V")
'.WriteString("SOURCE1:PULSE:DCYCLE 40")
.WriteString("OUTPut1:STATe ON")
.WriteString("SOURCE2:FREQUENCY:SWEEP 10HZ")
.WriteString("SOURCE2:FUNCTION:SHAPE RAMP")
.WriteString("SOURCE2:VOLTAGE:LEVEL:IMMEDIATE:AMPLITUDE 5V")
.WriteString("SOURCE2:VOLTAGE:LEVEL:IMMEDIATE:OFFSET 0V")
.WriteString("OUTPut2:STATe ON")
End With
regards
/Mikkel
mijq
Re: Setting the ramp symmetry in program
Post by mijq » September 24th, 2015, 7:09 am
Slight error: it is FIXED not SWEEP in the FREQUENCY statements.
/Mikkel
