Python 3: Save Hardcopy to PC, PyVISA - MSO/DPO 5K 7K 70K Series Scopes
Dave W
Post by Dave W » May 23rd, 2016, 4:30 pm
This example demonstrates how to use Python along with PyVISA to save hard copy screen images to the PC from MSO/DPO 5000, 7000 and 70000 Series Scopes.
# Name:  Save Hardcopy to PC using PyVisa for MSO/DPO 5K 7K & 70K Series Scopes
# Purpose:  This example demonstrates how to save a hard copy screen image from
#   the scope to the PC.
# Created:  2016-05-23
# Development Environment: Python 3.4, PyVisa 1.8, NI-VISA 2015, Windows 8.1
# Compatible Instruments: MSO/DPO 5000, 7000 & 70000 Series Oscilliscopes
# Compatible Interfaces:  USB, Ethernet
# Tektronix provides the following example "AS IS" with no support or warranty.
from datetime import datetime # std library
import visa # https://pyvisa.readthedocs.org/en/stable/
# Modify the following lines to configure this script for your instrument
visaResourceAddr = 'MSO5204B'
fileSaveLocation = r'C:\Temp\\' # Folder on your PC where to save image
rm = visa.ResourceManager()
scope = rm.open_resource(visaResourceAddr)
print(scope.query('*IDN?'))
scope.write("HARDCopy:PORT FILE;")
scope.write("EXPort:FORMat PNG")
# Set where the file will be saved on the scope's hard drive.  This is not
# where it will be saved on your PC.
scope.write("HARDCopy:FILEName \"C:\\Temp.png\"")
scope.write("HARDCopy STARt")
# Read the image file from the scope's hard drive
scope.write("FILESystem:READFile \"C:\\Temp.png\"")
imgData = scope.read_raw()
# Generate a filename based on the current Date & Time
dt = datetime.now()
fileName = dt.strftime("%Y%m%d_%H%M%S.png")
# Save the transfered image to the hard drive of your PC
imgFile = open(fileSaveLocation + fileName, "wb")
imgFile.write(imgData)
imgFile.close()
# Delete the image file from the scope's hard drive.
scope.write("FILESystem:DELEte \"C:\\Temp.png\"")
scope.close()
rm.close()
Carl M
Re: Save Hardcopy to PC, PyVisa - MSO/DPO 5K 7K 70K Series Scopes
Post by Carl M » June 15th, 2016, 11:43 am
my personal preference is to setup the instrument with a mapped network share and save directly to that.
