SCPI: Measure Voltage and Current
mclLeoben
Country: Austria
Post by mclLeoben » June 14th, 2016, 4:09 am
I'm reading a Keithley 2700 with SCPI sommands. with code below i got a error -410. I would like to measure current and voltage. I need your
help to make that possible.What could i do ? Thx
*rst"
 :trac:cle
:sens:func 'volt'
:sens:volt:rang 10
:meas:volt? 10, 0,001, (@101)
:sens:curr:rang 0.001
:meas:curr? 0.001 0,001, (@102)
Re: SCPI: Measure Voltage and Current
Post by Dale C » June 14th, 2016, 5:50 am
Your SCPI code is fine except for one thing.
You need to read the data back after you send the MEAS? command.
All these commands are sent with a "WRITE" command.
You need to retrieve the data with a "READ" command. This is usually an ENTER type statement in the programming language you are using.
Also, make sure the data string that will hold the returning data is long enough to hold all the returning data.
mclLeoben
Country: Austria
Post by mclLeoben » June 14th, 2016, 10:43 pm
Thanks for your response!Sorry,I forgot do define a read function and I have always insisted to find mistake in my code.
