Drawing for 016-2016-00
[email protected]
Post by [email protected] » September 2nd, 2016, 1:06 pm
Hi I have the drawing of 016-2016-00 for my TPP1000 probes. I need to put these thing on my PCB to measure some nigh frequency signals. By the way, where can I buy these 016-2016-00 ?
Re: Drawing for 016-2016-00
Post by David N » September 2nd, 2016, 4:46 pm
The 016-2016-00 is intended for use by existing customers that have previously purchased and designed the -00 version into their circuit board. The 016-2016-01 is a newer version that allows the user more flexibility when designing it into circuit board.
The -01 is not a direct replacement for the -00 version.
If you are just designing these into your testing environment, order the 016-2016-01. You can place your order by calling 1-800-833-9200, prompt 1 for sales.
[email protected]
Post by [email protected] » September 6th, 2016, 6:56 am
Can I have the drawing of 016-2016-01. Thank you.
Post by David N » September 16th, 2016, 10:48 am
See attached file.
016-2016-01 Probe to CB Test Point.docx
(68.28 KiB) Downloaded 1330 times
