AFG3011C get ip address programming
NDG1990
Country: Romania
Post by NDG1990 » November 16th, 2016, 6:37 am
Hi there,
I was wondering, is there any way to programmatically obtain the ip address of an AFG3011C signal generator ?
I've been looking throughout the programmer manueal but i didn't find anything.
Can someone help me please ?
Re: AFG3011C get ip address programming
Post by David N » November 17th, 2016, 10:36 am
I am not aware of any pro-grammatically command for obtaining the IP address. If the AFG is connected to the internet and you are remotely accessing the AFG, you would already have to know the IP address to connect to the AFG. Can you explain further your inquiry?
NDG1990
Country: Romania
Post by NDG1990 » November 18th, 2016, 5:36 am
The example from the capture gets the ip address and port for DPO/MDO oscilloscopes.
Basically, i'm communicating with the instrument using VISA.
Why i want to obtain it's IP address. Because for DPO/MDO oscilloscopes i will use the ip address in order to save the oscillosope's waveform as png.
I want to do the same thing for AFG3000 series signal generator.
Is it possible ?
Dave W
Post by Dave W » November 18th, 2016, 11:13 am
Hi NDG1990,
The AFG3000C series only provides provisions for saving screen images to a USB thumb drive plugged into the front panel. This can be done via the front panel controls or by sending the command HCOPy:SDUMp[:IMMediate] to the instrument via the remote interface.
The AFG3000C does not have a web server so there is no web page where you could go to get the screen image.
The only option for saving the screen image of the AFG is to a USB drive plugged into the front panel.
