Measurement of Current with constant voltage + Looping
ka3092
Country: Philippines
Post by ka3092 » February 22nd, 2017, 8:09 am
Good day!
I want to measure current values upon applying a constant voltage. I'm using the Keithley 2400 and KickStart. In the KickStart, I chose SMU simulator and then IV characterizer. How can I perform this measurement using the source voltage and measure current after I chose the IV characterizer? Is it possible to perform this measurement? I do not know which option to choose among the six given choices, namely Voltage sweep, Voltage bias, Voltage List Sweep, Current sweep, Current bias, and Current List Sweep?
I also tried to use the Communication terminal in the KickStart and I used the example commands in pages 1-15 to 1-16 of the Quick Start Guide document for the 2400 Source Meter. The SCPI commands do not work. I am also confused with this "*SourceMeter must be addressed to talk after sending :READ? to trigger and acquire data.". How can I perform this? What are the concrete steps?
I also would like to know about the looping mechanism of the commands? How can I execute this in KickStart? The total duration of one run of my experiment is 12000 seconds. I want to apply voltage for the first 600 seconds and then no voltage application for the next 600 seconds, I will repeat this cycle up to 12,000 seconds.
I hope you guys can help me on this. Thanks!
Users browsing this forum: Bing [Bot] and 2 guests
