3706 A, starting measurement before current output is turned on (3750)
Tomislav
Country: Austria
Post by Tomislav » March 29th, 2017, 11:22 pm
I am using 3706A and 3750 multifunctional card. I am able to apply current to heater from 3750 analog output and take
multiple 2 wire resistance measurements (I use dmm.measure() and dmm.measurecount()) while I am applying current. I am able to save the values in buffer and read them out. The problem is that I don't have time control between these two actions (applying current and taking measurement). I would like to start measurement 2 seconds before applying current from 3750 analog output. So far I didn't use trigger model.
Can someone advice me how to solve this problem ?
