AFG1062 & Arbexpress
NicolasB
Country: Canada
Post by NicolasB » October 3rd, 2017, 2:48 pm
AFG1062 does not exist in Arbexpress. What are the equivalent settings?
thanks,
Re: AFG1062 & Arbexpress
Post by David N » October 3rd, 2017, 4:51 pm
Correct, ArbExpress does not directly support the AFG1062. ArbExpress can import the data from a csv or txt file. Once imported, you would use the “save as” to save the imported file as a .tfw format to a USB flash dirve. Once on the flash drive, connect the flash drive to the AFG1062 and import the file into the AFG and then set amplitude and period to match your desired waveform output.
