Digital I/O ground potential
Model 2651A
shoverbj
Post by shoverbj » January 12th, 2018, 11:42 am
I have looked through the manuals and am unable to find an answer for this.
Are the ground pins of the digital I/O port (the DB-25) of the 2651a at the same potential or different potential from the negative (LO) output pin?
Re: Digital I/O ground potential
Post by Andrea C » January 15th, 2018, 8:13 am
The SMU LO is isolated from the chassis ground. The common mode isolation spec is 'greater than 1GOhm and less than 4500pF'.
