TekScope Utility Bug Reports
Dave W
Post by Dave W » May 8th, 2018, 9:48 am
This is the official location for bug reports for TekScope Utility.
Please post your bug reports in this thread only.
lars.winkelmann
Re: TekScope Utility Bug Reports
Post by lars.winkelmann » July 12th, 2018, 3:32 am
Hi Dave,
hardcopy from TDS3000 over Ethernet produces a error
error message
lars.winkelmann
Post by lars.winkelmann » July 12th, 2018, 3:48 am
Hi Dave,
it would be great to have a setting for the decimal separator independent of the local regional setting of windows
decimal separator
Dave W
Post by Dave W » July 18th, 2018, 4:00 pm
Hi Lars,
Thank you for reporting those. I will take them into consideration for a future update. The decimal setting should hopefully be something I can take care of with some settings in the .NET framework. The TDS3000 Ethernet issue... that instrument over Ethernet has proven difficult. I'll see what I can do there. Highly recommend GPIB though with the TDS3000 if you have it available. It seems to "just work."
Dave W
Post by Dave W » September 21st, 2018, 5:12 pm
Hi lars and everyone. I have a new build in the works (Sorry for the delay. I've been short on time) that will address the .CSV commas in the decimal place issue and will add MSO6 support. Don't think I'll get that TDS3000 Ethernet issue fixed though. I ran into similar trouble with the TDS3000 over Ethernet myself during development and could never quite get it to always work reliably. The TDS3000 is GREAT over GPIB, but Ethernet always seems troublesome.
lars.winkelmann
Post by lars.winkelmann » September 28th, 2018, 1:29 am
That are good news, when can we expect the new verson?
Dave W
Post by Dave W » September 28th, 2018, 9:59 am
Hi Lars. Other tasks have been preventing me from spending time on getting the release out. Check your PM though for a beta build.
Dave W
Post by Dave W » October 4th, 2018, 9:30 am
Hi Lars,
I was able to look into your TDS3000 hard copy transfer issue yesterday. On a TDS3054C the image transfer over Ethernet worked just fine. Then I noticed you were using a B model. I managed to find a TDS3054B and try it and I saw the same issue as you. Following the IO Trace I could see that the issue was that the scope was only outputting a null byte in response to the HARDCopy START command, rather than the image. I have no idea why it does this. Guess it's a bug that was fixed in the C model? Anyway, it took a little while to figure out how to get it to send out an image over the Ethernet connection, but what I ended up having to do is change the HARDCopy:FORMat from PNG to BMPColor and now it works. It has to transfer many more bytes now, but this does seem to fix it so your hardcopy issue will be gone in the next release.
stjude1982
Country: United Kingdom
Post by stjude1982 » July 4th, 2019, 1:19 am
Recently downloaded the TekScope Utility software for use on our MSO58 scopes.
I connected this up by USB and everything was fine - we were able to take screenshots as required etc.
However, the software is no longer connecting to our scope.
There is an error message as follows:
"The resource is valid, but VISA cannot currently access it."
Can you help to get this back up and running, please?
Regards,
Stephen
stjude1982
Post by stjude1982 » July 5th, 2019, 3:20 am
Wondering if the issue for this is in set-up?
The software does not seem to recognise the scope at all:
What should following options be set to:
Baud rate; Data Bits; Stop Bits; Parity; Flow Control?
Ps- Our MSO58 is updated with latest firmware V 1.16.6
Can't say for sure if I had this working prior to, or after the firmware update
Dave W
Post by Dave W » July 8th, 2019, 9:40 am
Hi stjude1982,
The Serial settings (Data Bits, Stop Bits, etc...) are only relevant to serial COM port connections (i.e. RS-232) so these do not affect USB connections.
The message you saw, "The resource is valid, but VISA cannot currently access it.," is a VISA error and not a TekScope Utility error. It is indicating that VISA cannot access the scope. What the error sounds like is that there is an issue with the USB connections that is preventing VISA from accessing it. If you have an open USB connection to the scope in another piece of software (such as the VISA interactive utility) this could be the cause of the issue.
If you could capture a trace of the communication between the program and the scope using the IO Trace utility, I could take a look at it and see if I see anything weird going on there. Start the IO Trace utility capturing before you plug the scope in all the way until you see the error in TekScope Utility and I can follow it and try to figure out what is going on.
MiMatt
Post by MiMatt » January 28th, 2020, 1:34 pm
Good Day,
again, I am very happy with the TekScope utility per my other posting.
Just one minor bug: When capturing Waveforms from my MSO2024, the colours for channel 1 and channel 2 are swapped vs. the original colours on the device itself i.e. CH1 is blue, CH2 is yellow. Original colours are CH1 is yellow, CH2 is blue.
Cheers,
MiMatt
Dave W
Post by Dave W » January 31st, 2020, 4:38 pm
Hi MiMatt,
The colors of the waveforms on the Waveform tab of TekScope Utility are assigned automatically by the Microsoft Chart control. This is why they don't match. I could tweak the code to explicitly assign them colors to match the scope. Something for me to consider for next release.
Sam_SB
Country: Switzerland
Post by Sam_SB » August 19th, 2020, 6:03 am
I installed the tekScope utility v1.2.2.11 and try to use the data logger feature to get the data acquisition of my MSO5204B.
I have the following message "input string was not in a correct format" when starting the log (refer to the attachment).
Also, when I select only the "Analog waveform", the data logger strats but in the csv file all the value for all channels is 0.
The same message appears when I try to get data on "measurement" tab.
Get hard copy and "get setup" is working well.
Could you please help me
Thanks in advance :D
SAM
TekScope utility error message.PNG (58.13 KiB) Viewed 848 times
Dave W
Post by Dave W » August 24th, 2020, 10:34 am
Hi Sam. Hmm... that sounds like the MSO5204B may not have measurement value available so it is returning values that are not numbers.
Do you have NI IOTrace software? If you do, could you run IOTrace and capture the command traffic when this happens and then save the trace file and send it to me? This will help me diagnose what is going on.
Thanks!
Sam_SB
Post by Sam_SB » August 24th, 2020, 11:24 pm
Hello Dave,
Thank you for your reply.
I get the NI IO trace capture when error occuring. I see "vi write" command running continuously.
In attachment you have the NI trace capture.
BR
Sam
Capture_NI.txt
(39.15 KiB) Downloaded 24 times
Dave W
Post by Dave W » September 10th, 2020, 1:51 pm
Hi Sam. Sorry I haven't been available to respond earlier. Thank you for sending the trace.
Looking at the trace I see that the measured value is coming back as 99.00000000000E+36 rather than an actual measurement value. This may be because the value is being fetched too early and for fetch delay is needed for the scope to produce a value. With that said, this should not be what is causing the not a number issue.
I think the issue is the parser in .NET is adapting to your localization settings and is expecting a ',' for the decimal point while the scope uses a '.' for the decimal and this is causing the parser to barf. I will need to make changes to the code to force the parser to use English localization (not sure when that will happen).
As a work around for you, setting the language for your computer in Windows to English should make the parser work again and get rid of that not a number error. If you try this, please let me know your results if this fixes it so I know the effort to override .NET's localization will be worth it.
Sam_SB
Post by Sam_SB » September 14th, 2020, 8:12 am
Hello Dave,
I changed the regional format to English in my windows as you suggested and it is working now!
Thank you for your support.
Sam
lars.winkelmann
Post by lars.winkelmann » January 11th, 2021, 2:25 am
Hello Dave,
I have a logging problem with the Tektronix TPS2000B series - that could be a bug.
If I activate "save on trigger" and "save analog waveform" while logging, the data is only saved when I press start/stop on the oscilloscope.
Although the scope continues to trigger, the software is still on armed and does not save. Am i doing something wrong?
2021-01-11 11_23_53-Window.png (20.8 KiB) Viewed 310 times
Dave W
Post by Dave W » January 11th, 2021, 10:49 am
Hi Lars. I don't have a TPS2000B to check it out. Can you capture an IO trace and send it to me? Start the capture before starting the data logger and let it capture a couple of cycles then stop it. That should hopefully give me enough information to see what is going on.
