Continous display refresh while measuring over GPIB
Forum rules
<t></t>
ahartmann
Post by ahartmann » November 8th, 2018, 8:32 am
I want to do some measurements with our new Keithley DMM7510.
We have used Keithleys 2002 before, where the commands to read a measurement looked like this:
  :FUNC 'VOLT:DC'
  :DATA:FRES?
The nice thing was, that between two value reads the display was continously refreshed with the current measurement value.
I'm now stucking a bit with the 7510, because here the display is *only refreshed* when a measurement command is issued. Between two measurements the display stays at the last value.
These are the commands I use:
  :FUNC 'VOLT:DC'
  :MEAS:VOLT? \"defbuffer1\", READ, SECONDS
What would be the easiest way to achive a continous display refresh?
Best regards,
A. Hartmann
ahartmann
Re: Continous display refresh while measuring over GPIB
Post by ahartmann » November 26th, 2018, 12:47 am
I have solved it with the following code for now:
:ABORT
:TRIGger:BLOCk:NOTify 1, 1
:TRIGger:BLOCk:MEASure 2, "defbuffer1"
:TRIGger:BLOCk:BRANch:ALWays 3, 1
:INIT
:FETCh? "defbuffer1", READ, SECONDS
Not sure if this is the best way to do such thing? I have to abort the trigger each time I want to change the measurement range, and re-init it again after. Beside that, it seems to work.
Any comments?
Best regards,
A. Hartmann
