TDS2000 : What is command for save/recall setup between PC and scope like as openchoice?
ArbExpress, OpenChoice Desktop, ExceLINX, LabTracer, KI-Wave, KI-Tool, etc.
nine523
Country: South Korea
Post by nine523 » December 11th, 2018, 9:21 pm
If I want to save/recall setup between PC and oscilloscope like as openchoice, is it possible?
In TDS2000 programmer manual (071-1075-03 or 04), only described with USB not PC.
To save/recall oscilloscope setting to file in USB, manual shown example like as below :
SAVe:SETUp “A:\PROD-TST\VID-EVAL.SET”
But no example for PC.
Please let me know it is possible with PC.
Thank you.
Best Regards,
ByungJun
Re: TDS2000 : What is command for save/recall setup between PC and scope like as openchoice?
Post by David N » December 12th, 2018, 9:15 am
You can try using the SET? (Query Only) command. It returns most oscilloscope settings. You can send these responses back to the oscilloscope to return the oscilloscope to the state it was in when you sent SET?. This query is identical to the *LRN? query.
nine523
Post by nine523 » December 13th, 2018, 12:32 am
Hi David,
I attached results after set? command.
Couldn't find PC location, would you guide how save/recall from PC to oscilloscope directly or thru USB?
Hard to find location example.
* Connected to: USB0::0x0699::0x03C3::C030617::0::INSTR
-> set?
<- *RST;:ACQUIRE:STOPAFTER RUNSTOP;STATE 1;MODE SAMPLE;NUMENV INFINITE;NUMAVG 16;:FPLED:MPKGREEN 0;:SOCKETSERVER:SOCKETPORT 4000;:HEADER 0;:LOCK NONE;:VERBOSE 1;:FINESTATE 0;:MESSAGE:SHOW "";BOX 272,53,273,54;STATE 0;:ALIAS:STATE 0;:DISPLAY:COLOR:PALETTE NORMAL;:DISPLAY:STYLE:DOTSONLY 0;:DISPLAY:PERSISTENCE 0.0E+0;CLOCK 1;FORMAT YT;GRATICULE 1;INTENSITY:WAVEFORM 35;GRATICULE 35;GLITCH 5;:DISPLAY:GLITCH 1;:FILTERVU:FREQUENCY 100000000;:HARDCOPY:INKSAVER 1;LAYOUT LANDSCAPE;PREVIEW 0;:-:PAPERSIZE DEFLT;IMAGESIZE DEFLT;PAPERTYPE DEFLT;PRINTQUAL DEFLT;DATEPRINT DEFLT;IDPRINT OFF;:DIAG:PWRTIMES 7;:SAVE:IMAGE:LAYOUT LANDSCAPE;FILEFORMAT PNG;INKSAVER 0;:SAVE:WAVEFORM:FILEFORMAT INTERNAL;GATING NONE;SPREADSHEET:RESOLUTION FULL;:SAVE:ASSIGN:TYPE IMAGE;:SELECT:ILVMODE AUTO;CH1 1;CH2 0;MATH 0;FFT 0;REF1 0;REF2 0;CONTROL CH1;:CH1:AMPSVIAVOLTS:ENABLE 0;:CH2:AMPSVIAVOLTS:ENABLE 0;:CH1:AMPSVIAVOLTS:FACTOR 10.0000;:CH2:AMPSVIAVOLTS:FACTOR 10.0000;:CH1:PROBE:GAIN 100.0000E-3;:CH2:PROBE:GAIN 100.0000E-3;:CH1:PROBE:FORCEDRANGE 0.0E+0;:CH2:PROBE:FORCEDRANGE 0.0E+0;:CH1:BANDWIDTH 100.0000E+6;:CH2:BANDWIDTH 100.0000E+6;:CH1:COUPLING DC;:CH2:COUPLING DC;:CH1:DESKEW 0.0E+0;:CH2:DESKEW 0.0E+0;:CH1:OFFSET 0.0E+0;:CH2:OFFSET 0.0E+0;:CH1:INVERT 0;:CH2:INVERT 0;:CH1:POSITION 200.0000E-3;:CH2:POSITION 0.0E+0;:CH1:SCALE 500.0000E-3;:CH2:SCALE 1.0000;:CH1:YUNITS "V";:CH2:YUNITS "V";:AUXIN:PROBE:GAIN 100.0000E-3;FORCEDRANGE 0.0E+0;:REF1:VERTICAL:POSITION 0.0E+0;:REF2:VERTICAL:POSITION 0.0E+0;:REF1:VERTICAL:SCALE 100.0000E-3;:REF2:VERTICAL:SCALE 100.0000E-3;:REF1:HORIZONTAL:DELAY:TIME 0.0E+0;:REF2:HORIZONTAL:DELAY:TIME 0.0E+0;:REF1:HORIZONTAL:SCALE 4.0000E-6;:REF2:HORIZONTAL:SCALE 4.0000E-6;:HORIZONTAL:POSITION 50.0000;SCALE 4.0000E-6;RECORDLENGTH 2000;RECORDLENGTH:AUTO 0;:HORIZONTAL:DELAY:MODE 1;TIME 0.0E+0;:MATH:TYPE DUAL;DEFINE "CH1+CH2";VERTICAL:SCALE 100.0000E-3;POSITION 0.0E+0;UNITS "V";:MATH:HORIZONTAL:SCALE 4.0000E-6;POSITION 50.0000;UNITS "s";:MATH:SPECTRAL:MAG DB;WINDOW HANNING;GATING:INDICATORS 0;:MATH:LABEL "";:FFT:SOURCE CH1;VERTICAL:SCALE 20.0000;POSITION -1.0000;UNITS "V";:FFT:HORIZONTAL:SCALE 4.0000E-6;POSITION 20.0000E-6;UNITS "s";:FFT:SRCWFM 0;WINDOW HANNING;ZOOM X1;VTYPE DB;:TRIGGER:A:MODE AUTO;TYPE EDGE;LEVEL 0.0E+0;LEVEL:CH1 0.0E+0;CH2 0.0E+0;AUXIN 0.0E+0;:TRIGGER:A:UPPERTHRESHOLD:CH1 2.3500;CH2 1.4000;:TRIGGER:A:LOWERTHRESHOLD:CH1 0.0E+0;CH2 0.0E+0;EXT 0.0E+0;:TRIGGER:A:HOLDOFF:TIME 20.0000E-9;:TRIGGER:A:EDGE:SOURCE CH1;COUPLING DC;SLOPE RISE;:TRIGGER:A:PULSE:CLASS WIDTH;:TRIGGER:A:PULSEWIDTH:POLARITY POSITIVE;WHEN LESSTHAN;WIDTH 8.0000E-9;:TRIGGER:A:RUNT:SOURCE CH1;POLARITY POSITIVE;WHEN OCCURS;WIDTH 8.0000E-9;:TRIGGER:EXTERNAL:PROBE 10.0000;:ZOOM:MODE 0;ZOOM1:STATE 0;SCALE 4.0000E-6;POSITION 50.0000;HORIZONTAL:POSITION 50.0000;SCALE 4.0000E-6;:HELPEVERY:ACQUIRE 0;TRIGGER 0;VERTICAL 0;MATH 0;FFT 0;CURSOR 0;REFERENCE 0;MEASUREMENT 0;UTILITY 0;:CURSOR:FUNCTION OFF;MODE INDEPENDENT;VBARS:POSITION1 0.0E+0;POSITION2 0.0E+0;UNITS SECONDS;:CURSOR:HBARS:POSITION1 0.0E+0;POSITION2 0.0E+0;UNITS BASE;:CURSOR:XY:READOUT RECTANGULAR;RECTANGULAR:X:POSITION1 0.0E+0;POSITION2 0.0E+0;:CURSOR:XY:RECTANGULAR:Y:POSITION1 0.0E+0;POSITION2 0.0E+0;:SEARCH:SEARCH1:STATE 0;TRIGGER:A:TYPE EDGE;LEVEL 0.0E+0;LEVEL:CH1 0.0E+0;CH2 0.0E+0;MATH 0.0E+0;REF1 0.0E+0;REF2 0.0E+0;:SEARCH:SEARCH1:TRIGGER:A:UPPERTHRESHOLD:CH1 2.3500;CH2 1.4000;MATH 490.0000E-3;REF1 490.0000E-3;REF2 490.0000E-3;:SEARCH:SEARCH1:TRIGGER:A:LOWERTHRESHOLD:CH1 0.0E+0;CH2 0.0E+0;MATH 0.0E+0;REF1 0.0E+0;REF2 0.0E+0;:SEARCH:SEARCH1:TRIGGER:A:EDGE:SOURCE CH1;SLOPE RISE;:SEARCH:SEARCH1:TRIGGER:A:LOGIC:FUNCTION AND;THRESHOLD:CH1 0.0E+0;CH2 0.0E+0;MATH 0.0E+0;REF1 0.0E+0;REF2 0.0E+0;:SEARCH:SEARCH1:TRIGGER:A:LOGIC:INPUT:CH1 X;CH2 X;MATH X;REF1 X;REF2 X;CLOCK:SOURCE NONE;EDGE RISE;:SEARCH:SEARCH1:TRIGGER:A:LOGIC:PATTERN:INPUT:CH1 X;CH2 X;MATH X;REF1 X;REF2 X;:SEARCH:SEARCH1:TRIGGER:A:LOGIC:PATTERN:WHEN TRUE;WHEN:LESSLIMIT 8.0000E-9;MORELIMIT 8.0000E-9;:SEARCH:SEARCH1:TRIGGER:A:PULSEWIDTH:POLARITY POSITIVE;WHEN LESSTHAN;WIDTH 8.0000E-9;:SEARCH:SEARCH1:TRIGGER:A:RUNT:POLARITY POSITIVE;WHEN OCCURS;WIDTH 8.0000E-9;:SEARCH:SEARCH1:TRIGGER:A:TRANSITION:POLARITY POSITIVE;WHEN SLOWER;DELTATIME 8.0000E-9;:SEARCH:SEARCH1:TRIGGER:A:SETHOLD:CLOCK:SOURCE CH1;EDGE RISE;THRESHOLD 0.0E+0;:SEARCH:SEARCH1:TRIGGER:A:SETHOLD:DATA:SOURCE NONE;THRESHOLD 9.91E+37;:SEARCH:SEARCH1:TRIGGER:A:SETHOLD:HOLDTIME 2.0000E-9;SETTIME 2.0000E-9;:MEASUREMENT:IMMED:DELAY:DIRECTION FORWARDS;EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:IMMED:TYPE PERIOD;SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS1:DELAY:DIRECTION FORWARDS;:MEASUREMENT:MEAS2:DELAY:DIRECTION FORWARDS;:MEASUREMENT:MEAS3:DELAY:DIRECTION FORWARDS;:MEASUREMENT:MEAS4:DELAY:DIRECTION FORWARDS;:MEASUREMENT:MEAS5:DELAY:DIRECTION FORWARDS;:MEASUREMENT:MEAS6:DELAY:DIRECTION FORWARDS;:MEASUREMENT:MEAS1:DELAY:EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:MEAS2:DELAY:EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:MEAS3:DELAY:EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:MEAS4:DELAY:EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:MEAS5:DELAY:EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:MEAS6:DELAY:EDGE1 RISE;EDGE2 RISE;:MEASUREMENT:MEAS1:TYPE PERIOD;:MEASUREMENT:MEAS2:TYPE PERIOD;:MEASUREMENT:MEAS3:TYPE PERIOD;:MEASUREMENT:MEAS4:TYPE PERIOD;:MEASUREMENT:MEAS5:TYPE PERIOD;:MEASUREMENT:MEAS6:TYPE PERIOD;:MEASUREMENT:MEAS1:SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS2:SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS3:SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS4:SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS5:SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS6:SOURCE1 CH1;SOURCE2 CH2;:MEASUREMENT:MEAS1:STATE 0;:MEASUREMENT:MEAS2:STATE 0;:MEASUREMENT:MEAS3:STATE 0;:MEASUREMENT:MEAS4:STATE 0;:MEASUREMENT:MEAS5:STATE 0;:MEASUREMENT:MEAS6:STATE 0;:MEASUREMENT:METHOD AUTO;REFLEVEL:METHOD PERCENT;ABSOLUTE:HIGH 0.0E+0;LOW 0.0E+0;MID1 0.0E+0;MID2 0.0E+0;:MEASUREMENT:REFLEVEL:PERCENT:HIGH 90.0000;LOW 10.0000;MID1 50.0000;MID2 50.0000;:MEASUREMENT:INDICATORS:STATE OFF;:MEASUREMENT:STATISTICS:MODE ALL;WEIGHTING 32;:MEASUREMENT:GATING SCREEN;SOURCESNAPSHOT CH1;:DATA:DESTINATION REF1;ENCDG SRIBINARY;SOURCE CH1;START 374;STOP 1623;RESOLUTION REDUCED;:LIMIT:STATE 0;SOURCE CH1;COMPARE REF1;SAVEIMAGE 0;SAVEWFM 0;STOPAFTER:VIOLATION:STATE 0;VALUE 1;:LIMIT:STOPAFTER:WAVEFORM:STATE 0;VALUE 100;:LIMIT:STOPAFTER:TIME:STATE 0;VALUE 60
Thank you.
Best Regards,
ByungJun
Post by David N » December 14th, 2018, 11:01 am
You would have to send the full command string back to the scope. What may be easier is a utility program written by one of our AE's. You can can find more information about it at: viewtopic.php?f=571&t=140451.
Return to “Other and Discontinued Software”
