taking 100 DCV measurements with constant duration using Keithley 2700
liuzhiyi18
Country: China
Post by liuzhiyi18 » January 15th, 2019, 6:00 am
Hi,All:
I want to use Keithley 2700 DMM to take about 100 measurements (DCV, single channel) with a constant time interval. I use SCPI command in MATLAB scripts.
In order to control the time interval, I use the following commands:
TRAC:FEED SENS
TRACe:POINts 100
TRAC:FEED:CONT NEXT
TRIG:COUN 100
TRIG:SOUR TIM
TRIG:TIMer 0.5
SAMP:COUN 1
READ?
However, the PC will receive only the latest reading.
How can I store all the 100 readings into the internal buffer, and receive all of them after the measurements?
Re: taking 100 DCV measurements with constant duration using Keithley 2700
Post by Dale C » January 22nd, 2019, 11:42 am
Start off the program sequence of commands with a
*RST
Then when ready to take data send the
:INIT
command.
Then when you want the data send
:TRACE:DATA?
That should send back all 100 points of measurement stored in the buffer when addressed to talk.
Hope this helps.
