Keithley 3706A using Labview
rizkyramadhan
Country: Indonesia
Post by rizkyramadhan » January 19th, 2019, 8:54 pm
Hello all,
I use Run TSP Script from Keithley 37xx library on Labview 2018 to run script on keithley. But I am not able to read buffer using Read Measurements Buffer library from ketihley 37xx on Labview. It always timeout. Can anyone hepl?
Re: Keithley 3706A using Labview
Post by Andrea C » January 20th, 2019, 1:14 pm
If always timing out, the basic VISA communication should be tested.
From NI-MAX, get a visa test panel for the 3706A. Can you successfully query *idn?
